Working on some particle animations inside a Popnet I created. I have the look the way I want it inside the Popnet, but if I go back outside the Popnet and see the same animation it looks completely different.
In the attachment, the top view is outside the Popnet, with the display flag on the Popnet.
The bottom is the look I actually want, inside the Popnet.
Am I missing some setting that might cause these to be drastically different?
Popnet Particle animations look different inside vs outside
3839 5 0- ShaneOShea
- 4 posts
- Enivob
- 2633 posts
It could be that when you are inside the network you have selected a node that is not the final node? So you are only viewing up to that point in the network. When you pop out one level the Output flag is honored and the viewport reveals the final result.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- ShaneOShea
- 4 posts
- ShaneOShea
- 4 posts
- goldfarb
- 3464 posts
- matthew_h_k
- 24 posts
