Point VOP Integer/Float to String Casting
   4973   2   1
I have been searching for a casting mechanism in VEX Builder space's node network. I have written a vex snippet with an empty string:“myString” and the integer:"myInteger value as inputs:
myString = itoa(myInteger);
I then take the output of myString. It works, but is a bit ugly and takes extra time and nodes to set up. Is there a node that can do this for me without my own VEX snippet?
I have searched for a solution for exactly this for a while, so even though this post is super old I thought I would share my solution. You can simply take the print node for this, just plugin in the integer and for the format string use: %. At least this worked for me.
brilliant solution, thanks romen !
Michal Tas Maciejewski @ www.vfxtricks.com
