Copy node result need to be exported as separate objects
   1624   1   0
Hi
Im tryinng to export the result of my copy node as separate objects to another application. I copied a cube on points, and I would like to export that to c4d (job requires). My only problem is, that I need every cube as a separate object.
Tried alembic, fbx, obj. Something is missing, but i dont know what. Can please somebody help? Thank in advance!
(yes im a new player, but trying my best. cheers)
You can create Unique Name Attribute based on each Cube , Then using Portioning section in the ROP Alembic Output node for making a hierarchy based on Name attribute . then you should have access to each cube in other 3D apps.
Rabiee.Sadjad@Gmail.Com
