Delete a group using an expression
   3896   4   1
OK, so I have a group named piece_318 that I want to delete at a specific frame number.
I put down a delete SOP and enabled the Delete by Expression.
I tried this, but it's not working: @piece_name = “piece_318” && $F > 10;
There is probably something I'm missing.
Any help would be appreciated.
Jim
Reel Inpsirations
Houdini Work in Progress [vimeo.com]
Hi
If you put:
piece_318
in the “Group” field of the delete SOP and
$F > 10
in the filter expression field, it will work.
-b
http://www.racecar.no [www.racecar.no]
I wish it did work.
Here is an example of what I'm trying to do.
delete_piece_on_frame.hiplc (101.8 KB)
Reel Inpsirations
Hi
Initially i though you could use @name=piece0 in the Group field, but it doesn't work the way I expected which was to only target “piece0”. It deletes everything after frame 2.
Another solution would be to use a Primitive Wrangle:
if(@name == "piece0" && @Frame > 2){
    removeprim(0, @primnum, 1);
-b
That's actually a more elegant way to do it anyway as I have multiple pieces I want to remove at various frame rates.
Jim
Reel Inpsirations
