Plead for Required Houdini Versions
   4135   2   2
Maybe this is only something that kind irks me, but could the updates to the Github Repo maybe use versions of Houdini that are actually available on the Daily Builds page?
It seems like every time I update the repo, the required Houdini build is generally a version that's not even available to download. ;_;
If you update to the latest commit you might have to wait a bit for the daily build to finish that day.
For older commits, try to stick to the commits that have the same version as the current production build.
Also, if you are just a few builds apart, especially in 15.5 and older Houdini versions, you can usually get away with manually changing the version numbers in your local repo to what you can still download from the Daily Builds.
We are working an a better solution to this for the future but I can't promise anything soon.
damian
Good enough for me.
<3
