DOPs Guide - Initial Draft
   2018   0   0
Well, lucky me, I just tried to post when the Early Access forum got locked.
jjStanley had just asked in this same-named thread:
Thanks JC, do you mean the help that is with each DOP? I have gone through most of them but it is always good to see a different take on how to use them.
True, unless the help is wrong. DOPs have changed a lot over the last few months. Helpcards are great, you can also approach it from the other end:
hdox/houdini/content/helpcards/ops_examples_dop.xml
with the examples first, which lead you to DOPs. Also, I assume you've already read the Intro to DOPs:
hdox/houdini/content/base/dyn.xml
J.C.
John Coldrick
