Vacuum space explosion
   3295   3   1
Hallo!
I'm trying to figure out how to properly do space explosion / impact on mars or any other planet that has no atmosphere.
I've read huge topic about smoke behavior: http://forums.odforce.net/topic/18397-get-rid-of-mushroom-effect-in-explosion-and-add-details-in-the-opening/ [forums.odforce.net]
At first, I'm trying to achive this:
How to force smoke to behave like simple, “lifeless”, unturbulent, dull, boring particles?
Or maybe, how to render boring particles as nice looking smoke (no luck with that either)?
What I've tried:
- somehow remove pressure (not sure I've done this right, but I could delete temperature, vel, density… but pressure without any luck)
- advect vel field itself (no difference in vel = no pressure), but that lead to uncontrolled vel turbulence, when used with more complex emitter.
- somehow blurring vel field and adding it when microsolver projectmultigrid was off to expand smoke.
- make those red particles a volume and to look like smoke, but there is problem with disappearing (they kind of always pop out of existence even if particles fade nice and slow).
I did something very similar with particles. The key is to have a lot, then play with size and opacity.
How did you render it? As volume? As lots and lots of points?
As lots of points, with a regular mantra shader
