VEX Attribute name as string from channel
   Views 9452   Replies 3   Subscribers 3
I am trying to find a way how to turn any string into an attribute name using VEX.
I have an wrangle posterising attribute but rather than hardcoding the attribute name I want to use String Channel to define which attribute to use, is there a way to do it? something like @'chs(“attributeName”)'… ?
Hi
Will this work for you?
string name = chs("attributeName");
int newatt = addattrib(0, "point", name, "...");
-b
http://www.racecar.no [www.racecar.no]
On the Bindings tab, add a binding and set the Attribute Name to reference your string parameter, and set the VEX Parameter to the name you want to use in the VEX code.
Great, thank you!
Both methods work, Binding seems like the cleanest solution..
