Painting maps or grouping guides in wire sim?
   2407   4   1
Hi all,
So far I am loving my time back in Houdini, and have had some fun with interesting tests like fluids pushing hair around, etc.
I am curious if there is a way of fine tuning things a bit with maps or groups? One thing I have been trying to do is simulate only SOME of the guides in my wire sim. I tried using the various group nodes, but it seems like you can only make the whole dynamic object a group which is counter to what I am trying to do.
Is this a scenario where I have to select the guides to simulate over in the SOP network and only push through those selected guides? I am also looking for a paintable way of selecting guides to simulate or even general hair finaling/cleanup (for shots) information. So far I'm not finding anything online or in the documentation.
Alex
I can't remember all the niceties of how I usually set it up as it has been a while. I do however have a nice example file for you!
I have marked it up in all the areas you will need to address, I hope this helps, it is a really efficient way to work.
Painting attributes is one of my all time favourite things about Houdini..
Cheers, Nick
paint_fur_dynamics.hip (3.5 MB)
Hi Nick,
This is great, thanks very much! When I open it, I get a lot of unrecognized parameters, so I'll look at reconnecting things.
Very cool, I appreciate the help!
Alex
Hi Alex, from memory I did this in H13 so there have been some major fur changes since then. Most of the errors should be benign, if you follow what I did and transpose it to a new version of Houdini it should all still work I think*
Cheers, Nick
Hi Nick,
Yep, working fine, thank you again! And it was my mistake, I forgot to put I was using H14.
Very helpful though!
Thanks,
Alex
