Use input mesh vertex colour but don't create colour set
   3426   1   0
Hey guys,
I was wondering if it's possible to use an input meshes vertex colour for something like scattering points but then deleting the vertex colour so that the output mesh doesn't have a colour set.
Mike
ignore_vertex_cd.mb (141.6 KB)
ignore_vertex_cd.hda (27.1 KB)
Hi Mike,
It seems like it's the vertex attribute N which is converted to color set somehow, if you add an Attribute Delete SOP and remove N from the vertex attributes then no color set should be created.
From my experience using Maya/Vray/Abc/Houdini combination, I have the feeling that it's a natural behavior with Maya to convert vertex attributes to Color Set to be able to use then in shaders like UVs for example but I might be wrong on that.
Hope that helps
Chris
Edited by chistof - Jan. 29, 2017 08:41:16
