Hi guys,
Is there any way to make the UI elements larger on high DPI screens? I already have the High DPI option enabled in Preferences but they're still incredibly small and the text is almost unreadable. Is there another setting I'm missing that I could be utilizing?
Any way to make the UI elements larger on High DPI screens? (Hi DPI is already enabled.)
8083 5 0- chrono1081
- 19 posts
- Siavash Tehrani
- 729 posts
Hi chrono, silly question but you did restart Houdini correct? I would think High DPI looks okay on a 4K-ish screen since everything is enormous at 1080p.
You can change the size of UI fonts. Copy the resources file from your Houdini install (for example C:\Program Files\Side Effects Software\Houdini 15.5.xxx\houdini\config\resources) to the config folder in your Houdini preferences folder. Edit the font sizes at the top and relaunch.
- chrono1081
- 19 posts
Yep I restarted and they are a little bigger, but still barely readable. The screen I'm running it on is 220ppi.
I'll give the config options a whirl. In the mean time I've been scaling the screen using the OS controls which works, but is annoying if you're using more programs than just Houdini.
Thanks for the config suggestion.
- old_school
- 2540 posts
I find the same issue on my MacBook Pro with retina display.
You can set the system environment variable HOUDINI_UISCALE and set it to 120.
If you use bash shells on the Mac or on Linux, do:
export HOODINI_UISCALE=120
On Windows best to set a system environment variable. Google how to set Windows system wide variables.
- goldfarb
- 3463 posts
- briankok
- 2 posts
Here is nice video on how to make the UI icons larger https://www.youtube.com/watch?v=a-eAOJqPq0M [www.youtube.com]
Brian Kokoszka
brian@briankokoszka.com
