newbie: deform by curve/ curve offset?
5221 10 1- Mladen Kevic
- 12 posts
Hello to everyone, i'm just moving from Softimage to Houdini, so i'm still in learning process.
For me best way to learn is to jump into fire (so i started new project right into Houdini)
maybe it's dull question but i didn't manage the right answer to it. i need to create conveyor (chain like) so i created object i and then add copy node it on resampled curve. So model is done, but i can't find a way to move it along that curve.
In Softimage i would use deform by curve deformer, and let curve that object is copied on follow that shape i want. but don't know what approach to use in Houdini, cause i cant find deforming by curve
Basically i need to create moving Tank Threads
thanks in advance,
Mladen
thanks in advance,
Mladen
- nisachar
- 83 posts
- sepu
- 462 posts
- matthias_k
- 483 posts
- matthias_k
- 483 posts
Sorry, small correction,
order must be set to 4 not to 2
comment is in file, too.
If you need better part placement, use “Bones from Curves” with measure for bone length,
then animate the bones…
If you need it in simulations maybe try a hinge.
- matthias_k
- 483 posts
One last note :-)
When I was working on accurate moving tank threads
main problem was exactly matching thread part length parts,
that's why I said “Bones from Curve” another approach,
which should be not visible in animation is maybe to use
a “Match Size” SOP, but if you play with the “resample1 -> length”
you'll notice the problem in a procedural construction :-)
In my opinion it depends on your needs.
Simple modelwith animation along path
or complex simulation in terrain?
Hope the attached file is helpy.
- nisachar
- 83 posts
- matthias_k
- 483 posts
Houdini keeps crashing when I try to load your file.
Hmmmm, usual v 15.5.
Then see construction video here:
http://the-final.com/houdini/Create_Tank_Threads.mp4 [the-final.com]
http://the-final.com/houdini/Create_Tank_Threads_Expression.mp4 [the-final.com]
should be easy to follow…
- matthias_k
- 483 posts
Do you mean use bones along curves kind of approach and then deform the Mesh by binding it to the bones ?
Yes, something like this:
http://the-final.com/houdini/Bones_from_Curve.mp4 [the-final.com]
If the bones become distorted, dive inside the “KIN_Chops” and move the “Blend” on the
“KIN_chain_bone” SOP. With this solution you can set individual length, but
to make it really procedural, you have much mork work.
- Mladen Kevic
- 12 posts
- nisachar
- 83 posts
matthias_kHoudini keeps crashing when I try to load your file.
Works ! Will try the bones next version to deform an existing geometry.
Thanks !!
