Any way to setup mplay gamma and lut per project?
   2197   2   0
I want change my mplay's setup per project.
My first approach was by using Environment variables and Mplay Profiles.
I set up environment variable from Houdini's Variables menu.
$GAMMA == 1
$LUT == /path/to/lut
Then Inside of Mplay Profiles Windows, change Cammandline Option to “-K -T -R -G $GAMMA -d $LUT”
Weird thing is, lut option work well with $LUT but gamma option does not work with $GAMMA. So it does not set 1 to gamma.
If anyone know how to resolve this, please let me know.
I also want to listen another way of doing project basis mplay setup.
Thanks in advance.
Edited by kybin - Feb. 23, 2017 22:49:51
If you export HOUDINI_IMAGE_DISPLAY_LUT and HOUDINI_IMAGE_DISPLAY_GAMMA, they should be picked up both by mplay and houdini sessions. If you want the settings to override the stored settings in a hip file you can use HOUDINI_IMAGE_DISPLAY_OVERRIDE to do so. As for ‘per project’, you need a way to control the environment per project.
Hi, jsmack. Thank you for the answer.
Unfortunately, it didn't work for me. Don't know why.
I am using Edit - Color Setting for lut, but it also doesn't handle gamma.
