I'm working on a leaf shader inside Houdini 16 and I came across strange problem.
I set up a dual shading model for PBR Diffue using ‘isfrontface’ condition, so for the front face I'm using Diffue and for back face Translucency and I get the result I wanted. But then when I plug in PBR Reflection after that, render gets stuck at 0.0% and nothing happens. Rendering without isfrontface condition with PBR Reflection layer works fine for both diffuse and translucency, but as soon as I add this condition Mantra is not respoding.
Any ideas why this is happening?
Attached shader network.
Thanks a lot,
Wojciech
Houdini 16 Shader: Mantra doesn't render when PBR Reflection layer is added to dual shading model PBR Diffuse
3195 1 2- wojciech_piwowarczyk
- 5 posts
- 5 posts
