Checking data types in VOPS?
   4094   7   0
I might have overlooked something obvious but in H15.5 and earlier i could check the data type on the pins of a VOP node by hovering over it, getting a description of wether it's an int, float etc etc.
In H16 the same behaviour just displays the name of the attribute. Any ideas on how to check the data type of a pin? Often i can deduce this from the context, but sometimes i have no clue.
Thanks,
Paul
I also interested in the answer.
nobody?
They are color coded.
- Green is vector.
- Light blue is float.
- Blue is integer.
- Beige is file/geo.
- Purple is matrix.
-b
Edited by bonsak - March 14, 2017 15:10:35
http://www.racecar.no [www.racecar.no]
This information has been added to the tooltips as of the next daily build H16.0.548.
It should have been there all along, as it was in H15.5. Thanks for pointing it out!
bonsak
- Green is vector.
- Blue is integer.
- Purple is matrix.
-b
Lol, what about all the structs tho?
You tell me
-b
Thanks mtucker - will look out for it in the next build
Edited by am-pm - March 25, 2017 08:50:38
