Hi Guys,
Very noobish question.
I have a jpeg image of a cad plan. I have applied it to the grid but how do I match it UV to the bitmap proportion? Something like in 3Ds Max where you just click match to bitmap with Box Projection Unwrapping.
Tried to find an answer but could not find anywhere? seems like people dont do much arch vis in Houdini
Getting to learn the Houdini but still need some basic first.
Bests
Image to Grid UV and match bitmap proportion.
4463 5 0- seijihg
- 2 posts
- Enivob
- 2626 posts
Drop down a UVTexture right after the grid. This will apply UV coordinates to it. If you need further UV tweaks drop down a UV Transform node and you can scale the coordinates, for instance to increase or reduce tiling.
Also, because you are a noob, I will mention the ever useful UV Quickshade. This will make a UV grid appear in the viewport so you can see how your UVs are applied across geometry. Just remember to de-activate it when it comes render time or you will still see that checkerboard pattern in your render.
Edited by Enivob - March 13, 2017 12:12:54
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- seijihg
- 2 posts
Many thanks for the tips very useful still they dont answer my question though
Is there a way to match uv mapping proportion to the image? so I dont have to play with changing number with UV Transform Node.
Been exploring and it seems like there is nothing like that so far.
All the best. Houdini is really good though. Now dont have to jump between Max and Reaflow/FumeFX.
One package for all
One package for all
- Konstantin Magnus
- 686 posts
Is there any particular reason you dont want to put the plan in the background of your orthogonal views, like press D and go to ‘background’?
- Konstantin Magnus
- 686 posts
Other than that you can just save the image_backdrop node in my example file as an asset (or drag and drop it on the shelf tools) and use it whenever needed.
Edited by Konstantin Magnus - March 14, 2017 12:51:34
- coccarolla
- 78 posts
I need to breathe new life into this thread, so has there something like the uvw map modifier in Max been added to Houdini in the meantime?
It would exactly benefit this scenario, where non-square plans need to be matched to geometry, or vice versa. And especially needed since sometimes I had to use 27k maps in one direction, which I don't want to make square for obvious reasons.
