I want to make a proper looking structure of a cheese, bread and alike.
I have a general idea and results. All I need now is to make noise making structure away from the surface.
I need to sample a sdf to have a fall of from surface.
notice how holes are contained within.
http://pngimg.com/uploads/cheese/cheese_PNG1.png [pngimg.com]
Artur
Cheese, bread...volume vop
3439 4 2-
- Artur Woźniak
- 7 posts
- neil_math_comp
- 1743 posts
I slapped together a quick attempt at this.
It'll take a bit of tweaking to get what you actually want, but this shows how to do something like this with the new Boolean SOP. You'll probably want to vary the shape of the holes a bit, using a For Loop block over the points, instead of just using Copy To Points, and you'll probably want to tweak the hole sizes and distribution.
- Artur Woźniak
- 7 posts
- Konstantin Magnus
- 675 posts
In VolumeVOP there is a bounding box (BB) value you can use as a gradient ranging from top to bottom.
- Artur Woźniak
- 7 posts
