Compressed fluid artifacts under the surface causing problems for whitewater
   Views 2604   Replies 1   Subscribers 0
Hey folks,
I am experiencing strange artifacts in my compressed fluid, happening under the surface (small dots / clamps of particles). It is also visible in one of sidefx's masterclasses:
https://www.sidefx.com/tutorials/h15-masterclass-flip-workflow-enhancements/ [sidefx.com] (minute 38:50)
It is not so problematic for meshing (at least not for my particular scene), but it messes up the white water emission because bubbles get emitted from those unwanted / artifact points.
I dived inside the fluid compress sop to investigate and saw that it has something to do with the surface field and culling. The culling leaves some points / chunks behind.
Did anybody experience the same and is there a fix to clean this up? (Beside cleaning it up manually by deleting points)
Thanks in advance for your time and efforts!
www.scratch-arts.net
Did you find any solution to that? I have the same «problem» as you.
