SyntaxError in python Script Sop
   2744   2   0
Hey,
I'm having trouble figuring out the ‘script’ node (Script Sop).
A simple box with a script node results in the following error:
Python error: SyntaxError: ('invalid syntax', ('', 1, 1, ‘/home/bruno.kindt/Library/projects/UE__BoilerRoom/BoilerRoom/Shop/scripts/test.py\n’))
even if the file is empty or has a simple `print “foo”` line.
I'm a bit suspicious about the ‘\n’ after the filename in the error message.
The contents of that line should be the script, not a path to the script. This matches the “Pre-Render Script” type script fields in the ROP operators.
Set the script to a
print ‘foo’
and you'll get the node printing foo when it cooks.
It is very confusing to have file choosers there; I'm not sure why we have them.
I looked into this…. Apparently, in HScript, if you try to run the command
foo.cmd
it will then execute the file foo.cmd if it is in the local directory. So this is why historically the file chooser made sense in these fields. But with python, of course, this does not work.
