Easiest way to convert ~500 '.obj' files to '.bgeo'?
7028 11 4- KalciferKandari
- 48 posts
- mark
- 2630 posts
- cwhite
- 748 posts
- KalciferKandari
- 48 posts
- Oluf Andrews
- 9 posts
- KalciferKandari
- 48 posts
- Oluf Andrews
- 9 posts
- KalciferKandari
- 48 posts
- nicoM
- 74 posts
- KalciferKandari
- 48 posts
Thank you very much, the script worked. Here is a more friendly version for others to see:
Copy and paste this to a text file and save as a ‘.py’ instead of ‘.txt’. Be warned, this will overwrite existing ‘.bgeo’ files if they have the same name as the ‘.obj’ file.
# Converts all the '.obj' files in a folder to '.bgeo' files, using the # 'gconvert' Houdini command, as such this script requires Houdini to be # installed. # Run using 'Command Line Tools' on Windows, and 'Houdini Terminal' on # OSX. import sys, os folder = "." # If the script is in another folder to the '.obj' files, put # the path in this string. for file in os.listdir(folder): if file.endswith('.obj'): path = folder + "/" + file geo = folder + "/" + file.replace('.obj', '.bgeo') command = 'gconvert %s %s' % (path, geo) print(command) if os.system(command): print('Error running command.') break
Edited by KalciferKandari - March 23, 2017 14:39:44
- blackpixel
- 182 posts
If you're on Windows, then you can create a simple batch script and put it in your “Send To” rightclick menu ( On windows 7 at least ).
Hit the windows key and type shell:sendto
It should open a folder >> C:\Users\your.username\AppData\Roaming\Microsoft\Windows\SendTo
Create a new textfile like _convert_to_bgeo, rename .txt to .bat and edit it:
( also change the path to your gconvert.exe )
Now select your OBJ files and right click > Send To > _convert_to_bgeo.bat.
Your files will now be converted one by one to bgeo.sc.
If you take out the /WAIT then it will launch a new process for each file.
This might be a bad idea with 500 files, but it's certainly faster if you have the resources.
You can do the same thing with textures to .rat files with iconvert.exe
@echo off
for %%i in (%*) do (
echo "converting %%~ni to bgeo.sc ..."
START /WAIT "" "C:\Program Files\Side Effects Software\Houdini 16.0.556\bin\gconvert.exe" "%%~nxi" "%%~dpi\%%~ni.bgeo.sc"
echo "done."
Edited by blackpixel - March 25, 2017 03:02:04
- JH12345
- 11 posts
Apologies for reviving an old thread here. I'm wondering if it would be possible to amend this script to make it work inside a series of folders, not just a single directory?
I have a workflow which will generate a large series of folders with .obj sequences inside each - is there a way I can make this script look inside each subfolder and make the conversion to everything in one go?
Thanks for any advice
Edited by JH12345 - Sept. 1, 2019 04:16:09
