Why does this not work; am I doing something wrong?
I expected a tiny little window to appear saying “Hello World”… but nothing seems to happen.
Fredrik
How to show simple PySide window in Houdini Apprentice?
16870 14 9- fredrikaverpil
- 14 posts
- rokandic
- 20 posts
Something like this should work.
from PySide2.QtCore import * from PySide2.QtGui import * from PySide2.QtWidgets import * class helloWindow(QWidget): def __init__(self, parent=None): QWidget.__init__(self, parent, Qt.WindowStaysOnTopHint) label = QLabel("Hello World",self) dialog = helloWindow() dialog.show()
- fredrikaverpil
- 14 posts
- rokandic
- 20 posts
- Konstantin Magnus
- 681 posts
Works on Houdini 16.0.504.20 on Mac OS 10.11.6 on my machine.
- fredrikaverpil
- 14 posts
Thanks guys,
On my Windows 10 workstation, also equipped with Houdini Apprentice (16.0.557) I can run the code from my initial post as well as rokl's code and a window appears but then Houdini freezes up.
Do you normally not run UIs from the Python shell in Houdini?
Edited by fredrikaverpil - April 3, 2017 02:38:29
- rvinluan
- 1269 posts
The Python Shell runs in a separate thread so you can get unexpected behaviour when executing PySide code from there since PySide/Qt needs to run in the main thread.
My suggestion is to instead create a shelf tool for scratch space and try out PySide code in there. You may have to register the created PySide widget with the hou.session module to avoid Python from cleaning up the widget when the shelf tool's script finishes executing.
For example:
I hope this helps.
Rob
For example:
from PySide2 import QtWidgets label = QtWidgets.QLabel("Hello World") label.show() # To prevent Python from garbage collecting the label widget. hou.session.dummy = label
I hope this helps.
Rob
- fredrikaverpil
- 14 posts
Hey Rob,
Thanks so much, that was it. Now it works great.
About registering the widget in a session; I'm importing a proprietary Python package which consists of many submodules and each submodule creates numerous widgets to present a user interface. What's the recommended approach in this case?
Should I register each and every widget (or window) with Houdini?
- rvinluan
- 1269 posts
You don't need to register every widget, only the root widget.
But check out the Window Lifetimes section in this help page:
http://www.sidefx.com/docs/houdini16.0/hom/cb/qt [sidefx.com]
It mentions another way of keeping the root widget alive by parenting it to the main Houdini window. In most cases this is actually a better approach since it means your PySide interface will persist across .hip file sessions unlike the hou.session method I mentioned earlier.
The section also mentions that the shelf script context is not automatically cleaned up when script execution completes which means your root widget will remain alive even without parenting or registration. So whoops, my bad on that one. You probably don't need to worry about any of this if you are launching the PySide interface from a shelf tool.
Rob
Rob
- fredrikaverpil
- 14 posts
Oh, excellent. Thanks - I was looking to parent the window to Houdini actually. In fact, I'd like to dock it if possible. I'll dig further into this.
By the way, do you know if there is any way I can execute Python code on Houdini startup?
For example with Maya, it looks for a “userSetup.py” file in a specific PATH. If found, it executes it. Anything like that with Houdini?
Cheers!
Cheers!
- rvinluan
- 1269 posts
Yup. Create a pythonrc.py script and put it in your $HOME/Library/Preferences/houdini/16.0/python2.7libs directory. You may have to create the python2.7libs subdirectory if it doesn't already exist.
Houdini will execute pythonrc.py on startup.
Here's the help for pythonrc.py and other scripts:
http://www.sidefx.com/docs/houdini/hom/locations [sidefx.com]
Rob
Rob
- VFXLife
- 16 posts
Hi guys, I've got a similar-but-different problem. My ui was built in QtDesigner, and I'm using PySide2's QUiLoader to load the ui. Launching it from the shelf, my code looks something like this:
The problem is that the UI shows up as a blank window. If I move the ui.show() line into the class itself (self.ui.show()), then the UI works properly. But this doesn't seem correct, and from there I cannot get the UI to close with any UI buttons using self.ui.buttonName.clicked.connect(self.close), even implementing a closeEvent() method, nothing works to close the window. Any ideas how to get QtDesigner UI files working in H16? Not sure what I'm missing here…
Thanks,
Chris
import hou from PySide2 import QtCore, QtGui, QtWidgets, QtUiTools class HDAManager(QtWidgets.QWidget): def __init__(self, parent=None) super(HDAManager, self).__init__(parent) ui_file = QtCore.QFile('/path/to/file.ui') ui_file.open(QtCore.QFile.ReadOnly) self.ui = QtUiTools.QUiLoader().load(ui_file), parentWidget=self) ui_file.close() # ... some more code ... def run(): ui = HDAManager() ui.setParent(hou.ui.mainQtWindow(), QtCore.Qt.Window) ui.show()
Thanks,
Chris
Edited by VFXLife - April 14, 2017 13:30:42
- blackpixel
- 182 posts
This should work:
import hou from PySide2 import QtCore, QtUiTools, QtWidgets class MyWidget(QtWidgets.QWidget): def __init__(self, *args, **kwargs): super(MyWidget,self).__init__(*args, **kwargs) ui_file = '/path/to/file.ui' self.ui = QtUiTools.QUiLoader().load(ui_file, parentWidget=self) self.setParent(hou.ui.mainQtWindow(), QtCore.Qt.Window) foo = MyWidget() foo.show()
Edited by blackpixel - April 15, 2017 10:58:08
- rudeypunk
- 113 posts
- rudeypunk
- 113 posts
I accidentally bumped into this solution that just may be a suitable substitute.
Instead of creating just call to a QT widget in Python shelf tool, I tried to create a Python Panel
and it worked like a charm!
Not overly complicated. No comes the complicated part of hooking things up
import hou from PySide2 import QtCore, QtUiTools, QtWidgets def onCreateInterface(): global theMainWidget ui_file_path = 'D:/TAHB/images/RTVFX/RTVFX/testInterface.ui' loader = QtUiTools.QUiLoader() ui_file = QtCore.QFile(ui_file_path) ui_file.open(QtCore.QFile.ReadOnly) theMainWidget = loader.load(ui_file) return theMainWidget
