Export mesh in FBX format with custom pivot position
   3755   1   0
I'm trying to export mesh/multiple meshes in fbx format using filmboxfbx node. Everything works fine except pivot point position. I need to set pivot at custom location, but it always stays at 0.0.0. The only solution I've found is to put the mesh at 0.0.0 by itself, but that's not ok since I want to export multiple objects in one fbx file and I just don't want to stack 50 objects at one zero-position)
Any hints? Thanks!
put your object inside the geometry node where you want the pivot to be (pivot is at 0,0,0 always it seems) then move the external geometry node position, that should work.
