easing animations and fx like these...
   3846   10   3
I did a lot of user interface work with Flash and iOS back in the day. An easing library was essential for doing motion effects like these. Being new to the world of Houdini, I was wondering if it had something similar? Where these types of animations are driven entirely by code.
Do some searching on the word “CHOPS”. Channel operations.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
Hi you can look at https://github.com/Aeoll/Aelib [github.com]
Aeoll did an amazing job, you can find his easing function in /vex folder
have fun
So I watched a couple of CHOP vids [sidefx.com]. A whole new world! Very cool.
To start simple, I thought I'd try and move a box 1 unit along the x-axis. But it doesn't move, it just gets distorted, so I'm doing something wrong.
simple_chop.hipnc (74.6 KB)
I think your setup is trying to move individual vertices. And you are successfully moving vertex #0 which causes the distortion.
What you can also do with CHOPs is fetch data from named channels directly. In this example I am fetching the CHOP result, which resides in named chan1, into the X location of the object iself. This way CHOPs moves the entire object with one value.
Edited by Enivob - April 7, 2017 15:59:00
ap_simple_chop.hipnc (55.1 KB)
Okay, that got me a little farther. I replaced the Wave node with a plain Channel node. My TransformVOP now moves the cube over 1 unit in the x-axis correctly. However, I guess I have a misconception about how CHOPs work as I was expecting it to do +1 unit every frame, creating motion.
Update: movement without chop, using a simple point vop.
simple_no_chop.hipnc (73.5 KB)
CHOPs can continuously move something along an axis, but you have to consider how the waveform would look. It would essentially be a rising ramp.
Simple tween from attribute wrangle.
simple_tween.hipnc (57.2 KB)
I attached some VEX/python examples for the animation you posted on easing, parenting, delays, transforming and counting.
motion_principles.hipnc (102.8 KB)
Thx Magnus, I learn a lot from the hip files you post.
