Using VEX to create groups by attribute
   65830   14   6
I want to create an arbitrary number of groups based on an attribute using VEX. The basic set-up is pretty simple:
Put down some Geo > Scatter arbitrary number of points on Geo > Feed those points into POPNet > Feed particles from POPNet into a Trail SOP > Use Add SOP to create lines from particle trails by grouping by attribute (id). That works great but I want to use VEX to create the groups instead of using the Add SOP.
My problem is that I haven't been able to figure out the correct VEX syntax, in particular, how to set the group name to the @id attribute (each trail inherits the @id of the originating particle) like so:
i@startpoints = chi(“../scatter1/npts”); // get the number of scattered points
s@test = itoa(@id); // convert id to string
for (int i=0; i < @startpoints+1; i++){ // loop over points
s@groupname = concat(“group_”, @test); // this creates strings matched to @ids, e.g., group_0
// not what I need
if (i==@id){
i@group_***** = 1; // ***** is where I'm stuck, how to read i into the groupname
} // I thought I could use ` ` to read it in but that fails. ?
I can achieve the effect I need with the Add SOP but I feel like I'm missing something in my understanding of VEX here and would love to sort it out. Any help would be much appreaciated.
Edited by kevinthebright - April 10, 2017 13:05:51
Maybe try using the vex function setpointgroup:
http://www.sidefx.com/docs/houdini/vex/functions/setpointgroup [sidefx.com]
Edit: Also, I've noticed that on your line;
s@concat(“group_”,@test") = 1; // create group for each id - this doesn't work
It looks like your trying to assign 1 to a string. Maybe 1 can't be implicitly cast?
Edited by BabaJ - April 10, 2017 12:53:16
Hi BabaJ,
Thanks! Setpointgroup works perfectly! The string concat work (creates the string). I meant it didn't accomplish what I needed. I'll edit to clarify that. Here's the final code in case its helpful for others.
s@test = itoa(@id);
if (i==@id){
setpointgroup (0, @groupname, @ptnum, 1, “set”);
Why are you binding all of your variables to attributes, is this just for testing?
You also appear to be looping over the points, and comparing index to id. Normally, you can just bind id since you are building the group name directly from id anyways.
your code can be simplified to:
string prefix = chs("prefix");
string groupname = sprintf("%s_%d", prefix, @id);
setpointgroup(0, groupname, @ptnum, 1);
Thanks for this jsmack. I see what you did.
Yes, I usually bind variables while writing VEX so I can see them in the geo spreadsheet. I set up a loop so I could do other stuff to the group.
-k
Hi kevinthebright:
I suspect you already know this…but if in cases where the only reason you bind a ‘variable’ so that you can see it in the spreadsheet; There is another option.
I sometimes create Detail Attributes for ‘data sets’ in vex to be used multiple times elsewhere in my Network but have no need for the points, prims or say vertices that the data was derived from (in the context that I am using the data sets.)
In those cases when they are not bound they still show up and are available to view in the spreadsheet under the Detail tab.
I hadn't thought of that approach BabaJ. That's handy, thanks.
Hello! I'm little confused with reading existing group in vex editor (Attribute Wrangle). Can't find in documentation mention of this. Example: Exist one group of Points “group1”, need call this group using vexpression. If I use “@”, it just creating new attribute.
Hi Felix6699
Here I set up some colors, then create 3 groups, an allPoints group, a neg_zed group and red group, then call the neg_zed group in an if loop. Does that help?
@Cd = set (0, 0, 1);
if (@P.x > 0){
    @Cd.r = 1;
i@group_allPoints = 1;
i@group_neg_zed = @P.z < 0;
i@group_red = @Cd.r > 0.6 ? 1 : 0;
if (@group_neg_zed == 1){
    @Cd = @P.z;
Also, as ever, check out Matt's blog:
http://www.tokeru.com/cgwiki/index.php?title=HoudiniVex#Access_group_names_procedurally_in_vex [tokeru.com]
Hi, kevinthebright!
Yes, if we will write i@group_NAMEGROUP, we can call exist group. Strange, that I missed it somewhere in the documentation. Thanks a lot
Not sure what you mean by ‘reading’ but there is an easy way to get points, primitives or edges from an existing group in vex;
expandpointgroup
expandprimgroup
expandedgegroup
http://www.sidefx.com/docs/houdini/vex/functions/expandpointgroup [sidefx.com]
http://www.sidefx.com/docs/houdini/vex/functions/expandprimgroup [sidefx.com]
http://www.sidefx.com/docs/houdini/vex/functions/expandedgegroup [sidefx.com]
Felix6699
http://www.sidefx.com/docs/houdini/vex/snippets#accessing-group-membership [sidefx.com]
http://www.sidefx.com/docs/houdini/nodes/sop/groupexpression [sidefx.com]
FX Supervisor
Method Studios, NY
kevinthebright
Hi Kevin, so i have used this code to create point attributes with lets say "group_0", "group_1" etcc but i want to convert these point attributes to actual groups... so basically the points i have assigned an attribute "group_0" to convert them into a point group with the same name...
any help would be greatly appreciated... thanks!
Onyro
Hi Onyro, By actual groups, I take it you are not seeing the groups when you click on the node information? Is your wrangle after the trail SOP? You should be able to create a group from any attribute with the i@group_groupname = 1 syntax. For example, i@group_blueteam = (@Cd.b == 1) ? 1 : 0; sets a points membership to the blueteam group if point's blue color value is 1. Post your hip if you get stuck.
So, is it also possible to use the created group immediately. So in the same wrangle? Instead of using multiple wrangles and selecting the group.
Lets say something like this?
if(@P.z <= 0)
i@group_max = 1;
if(@P.z >= 0)
i@group_min = 1;
// just a sample expression
if(i@group_max=1)
@Cd = set(0,1,0);
if(i@group_min=1)
@Cd = set(0,0,1);
