Control keyframe value by relative reference
   3339   5   1
Hello. I have a problem.
Assume, you have an animation in ty param. Three keys with values: 0, 2, 0. I would like to limit second key. value 2 should depend on another geometry position or any other data or parameter. 0 and 0 doesn't change. Curve should be bezier between values 0 2 and 0.
What solution should I use?
http://c2n.me/3Jqr21W [c2n.me]
Edited by evgen - April 11, 2017 15:23:52
can you just multiply by a channel reference?
bezier()*ch("/obj/obj1/ty")
if your bezier curve is 0,1,0
and your channel reference to say ty of another object is 2.0
then the result will be 0,2,0 etc.
FX Supervisor
Method Studios, NY
Hello Tomas.
That's partly good solution. thanks!
I will try.
But in fact, it would be very nice to have keyframe value control this manner - just by relative reference to value.
you can do that on per keyframe basis
FX Supervisor
Method Studios, NY
tamte
How would you do that on a per key basis?
Is there any solution for a channel reference "per keyframe basis"?
Would be extremely useful in simulation to wedge just certain animation keys on the animation curve...
Edited by ervin3d - March 20, 2021 09:55:30
