ERROR: Internal error: The noncommercial user could not be found
   2895   2   0
I'm trying to install Houdini 16 apprentice on Linux Manjaro 64bit but when I run
houdini
I get this :
I click Next, accept the terms and I get this :
so I go to http://license.sidefx.com/get_nc_license.php, [license.sidefx.com] select “Houdini (Non-Commercial)”, “Houdini 16”, enter my server name and server code according to
sesictrl -n
and get :
“ERROR: Internal error: The noncommercial user could not be found”
When I open the Houdini License Administrator with
hkey
I get this :
What should I do ?
Edited by ChameleonScales - April 16, 2017 10:19:42
Try running happrentice instead of houdini. Houdini is the full version Apprentice is the free version.
Also try that URL in the message box or just contact support@sidefx.com.
Edited by Enivob - April 16, 2017 09:27:35
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
OMG Thank you ! I didn't see this “happrentice” command anywhere in my research. I wonder where it's documented.
About the URL in the message box, I tried it as explained earlier but I apparently uploaded the same screenshot twice, which may have confused you, so I just fixed it and put the proper image.
But problem solved anyway ! (can we mark topics as solved here ?)
Edited by ChameleonScales - April 16, 2017 10:26:52
