Hi.
Is it just me or it's a common issue:
Operator Path inputs has to be reassigned every time for every digital asset that are already placed on the map after reopening unreal engine project. If it's not done, after rebake or any other asset modification in UE, the digital asset thinks that it's operator path inputs have no data assigned to them.
Very simple example:
1. Create digital asset that scales object from operator path input by 10.
2. Import to UE.
3. Create a map.
4. Place a cube.
5. Place an asset onto the scene.
6. Assign cube to digital assets operator path input (world outliner input -> select cube)
7. See the result. Cube scaled by 10. All good!
8. Save the map and close Unreal Engine.
9. Reopen Unreal Engine, open saved map.
10. Click “Recook Asset”. Error here. Houdini icon mesh will be displayed instead of scaled cube. Which means that there is no cube assigned to operator path input. But it does!
11. It can be fixed by reassigning the cube to digital asset's operator path input and recooking again. But after another project launch it has to be done again and again and again.
How can it be fixed? Thanks!
Assets not works properly after project restart
4019 3 0- Ivan_Titov
- 7 posts
- dpernuit
- 553 posts
- dpernuit
- 553 posts
- Ivan_Titov
- 7 posts
