rotate objects randomly on certain axis
   17506   3   0
I've been using Houdini for a bit now and I am loving it, however I feel I am missing something simple. I am copying an object along a spline with multiple points using the copy to point node. However I would like each object to have a little bit of random rotation (preferably a range that I can set) on a certain axis. Is there a tutorial for this or a simple answer, I feel I will kick myself when I finally see a solution.
Thanks in advance.
Regards
Joel
Hello.
Use copy stamping.
In this case you need to use copy stamp node not copy to point.
https://vimeo.com/90491383 [vimeo.com]
Edited by Nima - April 27, 2017 11:12:50
Copy stamping will work, but is unnecessary in this case. It will also make your network much slower, since each copy needs to be evaluated individually.
Using N or Orient, you can align your copies along the curve, and use attribute randomize to adjust the copies. There are, of course, many ways to achieve this. This is just a simply way.
.hip attached.
RandomizeAxis.hip (86.4 KB)
Scott Keating
Product Designer
SideFX Software
This was also answered a few days ago:
https://www.sidefx.com/forum/topic/49431/ [sidefx.com]
