how can one produce a hex grid in houdini ?
   Views 31529   Replies 20   Subscribers 8
silly question but is there any quick or easy way to make a hexagonal grid in houdini ? would like to make a map based off a system using said grid in order to make a procedural map with more polished peaces to puzzle together.
there's probably a sweet mathematical way, and my idiot way;
-put down a grid
-divide sop, enable ‘compute dual’
-transform sop rotate 45 degrees around Y
-another transform to scale it along x so the hexagons are symmetrical
-delete in bounds mode to trim it back to a square of hexagons
hexagons.hipnc (55.5 KB)
haha nice! I think the platonic soccer ball copied your idea
A rough implementation of a hexgrid algorithm would be connecting two attribwrangles: Set the first one to detail and the second one to run over points.
// Creates a point grid in detail mode
for(int j = 0; j < 10; j++){
    float shift_x = ( (j + 1) % 2 ) * 0.5;
    float shift_z = j * 0.75;
    for(int i = 0; i < 10; i++) {
        vector pos = set(i + shift_x, 0, shift_z);
        addpoint(0, pos);
// Draws hexagonal polygons on the grid
int prim = addprim(0, "poly");
float height = (sqrt(3)/2) * 0.5;
float width  = 0.5;
for(int i = 0; i < 6; i++) {
    float angle_deg = 60 * i + 30;
    float angle_rad = $PI / 180 * angle_deg;
    vector pos      = set(@P.x + width * cos(angle_rad), 0, @P.z + height * sin(angle_rad) );
    int pt = addpoint(0, pos);
    addvertex(0, prim, pt);
If you want to dig a tiny little deeper, here is the source:
http://www.redblobgames.com/grids/hexagons/ [redblobgames.com]
http://www.redblobgames.com/grids/hexagons/implementation.html [redblobgames.com]
thank you all for the help. was stuck at work last few days. will be trying some of these methods out tonight.
Hey!
Thanks for the examples shown.
@mestela
How you understood that we need to put 0.6 in second transform's x Scale to make polygons symmetrical? Is there a kind of logic in it or you've found that it works by tweaking scale?
@Konstantin Magnus
You have four nodes for this (grid + attribute wrangle + attribute wrangle + null)? I have source grid visible after hexagons are created, you've added some anoter node to delete it, or I did a mistake in code retyping and something there delete grid? Yours hexagons look the same sized on the image uploaded, but how do you know that they are? Is there something in written shows you that it is so? Using what in code you adjust spacing between hexagons?
Thanks for possible replies and advices
Edited by ryuku - Nov. 22, 2017 06:06:35
The 0.6 I just got by eyeballing it.
@mestela Thanks
Hi Ryu,
Ryu Ku
No, just two wrangles (see attachment).
Ryu Ku
Multiply the same value on height and width.
hexagons.hipnc (70.9 KB)
@Konstantin Magnus
Couldn't imagine that we don't need grid object for this. Now it's clear. With width and height too. Thanks
so here's my way…it boils down to divide and conquer…or translated to: create a unit of something, clone it, offset it, radial clone it…whatever….it's just cloning…
I'm not a coder so cannot cram things into one wrangle…but for other non-programming ppl out there..you can look at my files here:
https://www.facebook.com/groups/HoudiniArtists/permalink/1467625033353296/ [www.facebook.com]
step-by-step are pretty easy to understand…it's just cloning, offsetting…
(oh yes…mine produces points…so technically not a grid)
Edited by vusta - Nov. 24, 2017 02:37:16
@vusta If you're talking about hex grid example, would be nice if you'll upload it here, interested to look in , but I don't have Facebook account
Cool!
Mestela's approach shows how a bit of node-fu and creativity can quickly take you out of a ditch.
Konstantin's vex method is the preferable one if you want your hexagons to be “perfect”.
Thanks for sharing these guys!
Edited by anon_user_89151269 - Nov. 24, 2017 04:59:48
Ryu Ku
Edited by vusta - Nov. 24, 2017 06:03:18
vu_honeycomb_02.hipnc (105.5 KB)
@vusta
Very interesting approach to create hexagon, you've reminded me that I need to find out how to work with For-Each Loops still don't know it Changed you packing tube to six Columns, like the effect it gives and like how you've called the file, didn't think about miel before it relatively to hexagons Thanks for the example
Edited by ryuku - Nov. 24, 2017 13:20:51
I tried to replicate the code of Konstantin Magnus and the hex was always squished a bit. What gave me an regular hex was this. Took me some time to figure out because I don´t know my way around math very well. Perhaps it can be of help to someone.
@Konstantin Magnus Thanks for the starting point and the wonderful Red Blob Games [www.redblobgames.com] link
float size = 0.5;
    float angle_deg = 60 * i-30;
    vector pos      = set(@P.x + size * cos(angle_rad), 0, @P.z + size * sin(angle_rad) );
Saw this post a while back and wanted to give it a whirl but didn't have the time…had time today.
I seperated the hexagons into two vex nodes - one for just creating the hexagons points (their hex “corners”).
And the second to make them into polylines or polygons.
The third node is an add node just to quickly create the polygons by attribute ( in this case the hex number ).
Both vex nodes have a folder tab with control paramters.
The first vex node name “Create Hexagon Points” has the following controls:
* Hexagon starting point
* Hexagon Radius
* Number of Hexagons per row
* Number of Rows
The second vex node has the parameter to switch back between polys or polylines.
Edited by BabaJ - May 4, 2018 21:37:47
Hexagons.hiplc (80.1 KB)
A non-mathematical approach would be
  • a grid with alternating triangles,
  • grouping its crossing points,
  • scaling it by ~1.7 along X,
  • and copying six sided circles on them.
  • A fuse will cover tiny imprecisions.
hex_grid.hipnc (72.3 KB)
Because there's always room for more methods?
Here's a super simple solution based on a tetrahedral Points From Volume SOP.
There used to be more here, until I realised that I didn't need most of what I'd put down. Delete delete delete…
Edited by Nick Wood - May 23, 2018 11:32:16
hex grid 2.hiplc (209.3 KB)
Thanks to everyone for your methods. I made my own super simple method, that converts the default grid to hexagonal grid using ‘pointsfromvolume’ node with Tetrahedral point configuration.
You can easily control grid size, hexagon size (Point separation in the ‘pointsfromvolume’ and hexagon offset (circle radius).
hex_grid_STEVLTH_edition.hipnc (110.8 KB)
