Hi there,
H8.0.421
When you MMB on an RSL VOP's color parameter and choose “Create Parameter” (or “Create Constant”), it creates a parameter of the wrong type (vector).
The color type seems to be the only one with this problem.
It only happens with float parameters whose matching input type is ‘color’… which, now that I think of it, is probably an invalid definition. On the other hand, that *is* a valid definition for point, vector, and normal types (in rsl), so I thought ‘color’ would follow the pattern… but then ‘color’ is native to both rsl and vex whereas the others aren't, so maybe it expects to be treated as a true type… sorry, rambling now…
BUG: RSL VOP Create Parameter
2300 0 0- Mario Marengo
- 941 posts
