Issues while wrapping cloth around tube
   4099   3   0
in my scene I try to continuously wrap a piece of cloth around a geometry but the cloth doesn't stabilize and starts to jitter. I tried different cloth setting, changed stiffness and damping and increased the substeps but I can't get rid of the jitter. Has anyone experienced the same behaviour? What are the crucial settings to get the mesh static? Is it possible to exclude some points/edges from the clothsim based on conditions?
Any hints or tips on this matter would be very appreciated. Here is an image and a scene file for better understanding of the issue.
Thanks in advance.
CLOTH_WRAP_TEST.hipnc (239.1 KB)
Yep, I agree, the Cloth solver is broken. You may want to submit this file to support@sidefx.com as a bug. There does not seem to be a fix for this at this time.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Hm, okay thanks Enivob.
Hi, I just wanted to say that I did the setup now with POP-Grains which works much better.
Edited by Xue_Yue - May 11, 2017 07:45:32
grain_wrap.hipnc (343.0 KB)
