Hi All,
I'm trying to follow this tutorial https://vimeo.com/89039534 [vimeo.com] and I keep getting errors when I add the Flat Tank.
Anyone know what is causing this?
I'm running latest version of Apprentice.
Problems with flat tank, trying to follow tutorial
3955 4 0- adburns
- 20 posts
- Enivob
- 2629 posts
- adburns
- 20 posts
- michael-h
- 4 posts
I had the same issue.
To fix it, you can either uncheck “Kill inside Collision” on the “wavetank” (Ocean Source).
Or, make the “wavetank” editable (right click “allow editing of content”), dive inside, find “collision_sdf”, and on the the Voxel Size param delete the channel and set a value manually (eg 0.2).
Hope it helps!
Michael
Hope it helps!
Michael
- rgoldade
- 73 posts
