deleting prims with centroid within bounday
   3807   8   2
hi,
how is it possible to check if prim's centroid is within an other specific volume (mesh)?
I know I can use the group so to test if points are within a volume and delete those points, but how would I do this for a primitive?
any input welcome!
thanks,
m.
something like this?
in_boundary.hip (77.3 KB)
perfect - spot-on!
thanks so much!
matt
Here is a VEX solution that evaluates the normal directions of your mesh volume against the direction of the primitive centroids towards the closest points of the mesh volume.
prim_centroids_in_mesh.hipnc (259.8 KB)
thanks for the additional input - that's a cool alternative!
hi .. re the solution by matthias_k.
I actually can't use this approach, as the ‘centroid points’ for concave polygons can actually be outside the polygon and therefore within the volume I test against, which causes errors. But thanks for the input!
where is your ‘centroid’ then in a case like this?
many thanks for the response
Hmmmm,
the question from Konstantin is perfect.
Maybe you need to convert every prim via primitive SOP to zero
and then check if the zero scaled prim points are inside your
“check against” geo.
But this can be slow, if I'm right
