combining-solvers-with-a-multi-solver Tutorial does not work
   2618   1   0
Hello there,
Newbie to houdini, newbie to english language, newbie to programming : i'm stuck following some tuts.
this one for exemple :
https://www.sidefx.com/tutorials/combining-solvers-with-a-multi-solver/ [www.sidefx.com]
i try to follow the instructions step by step
but when i had the pop curve force node and i set up the follow scale and suction scale parameters as mentioned in the tutorial : nothing happens.
can someone help : i'm sure it's a newbie mistake but i'm lost
thanks
Edited by Grego - May 29, 2017 12:54:26
popSolverTest.hipnc (260.3 KB)
in your curve1, Untick Close…you also should move the end points closer so they ‘look’ like they're joined…otherwise..when the boxes get to the end, they spray apart
