volumes and transformation matrix
   Views 7525   Replies 5   Subscribers 0
Hi!
I am trying to transform a volume with a matrix with no luck so far.
Multiplying by the transformation matrix works on a polygon object but not on a volume
I am guessing this has to do with the fact that the volume only has one point?
I found a workaround: extracting the transformation values and then point()reference those values on a transform node
But I really would like to understand why is the matrix not working on volumes, while the Transform SOP is?
I am missing something important here I think
Is there a way to use a matrix to transform a volume?
transform_volumes.hipnc (157.1 KB)
Use the Transform by attribute SOP, or set the ‘transform’ primitive intrinsic. The first method lets you create a matrix attribute per point, the second requires you to set the rotation/scale component as a matrix3 on the primitive and the translation by updating ‘P’ of the point.
http://www.sidefx.com/docs/houdini/nodes/sop/xformbyattrib [www.sidefx.com]
http://www.sidefx.com/docs/houdini/vex/functions/setprimintrinsic [www.sidefx.com]
Hi jsmack!
Thanks for your answer
Transform by Attribute works like a charm, thanks.
I did not know about primintrinsic:transformattribute
I tried to do it the way you suggested:
- change @P
- set the primintrinsic:transformto a rotation/scale matrix (matrix3 right?)
Well, I could not make it work that way.
The only way I found is to set the primintrinsic:transformas a 4x4 matrix and not set @P
Weird because here [www.sidefx.com] they also mention primintrinsic:transformas being a matrix3…
Did they change anything in 16?
I could not find anything related in the doc [www.sidefx.com]
Is there a list of all the primintrinsic with their type, definition and use?
I updated my file with a transform_volume_02 geo node with my comments in it, if you want to have a look.
transform_volumes_v02.hipnc (1.7 MB)
Hi!
So I investigated a bit further and found out that the matrix4 method works only for VDBs
Matrix3 + setting @P is actually the way to go for other primitives
So I test the size of the matrix before applying the transformation
Then I chose which (matrix3 or matrix4) to apply depending on the size
I really would like to understand why VDBs are treated differently
If anyone knows…
thanks!
transform_volumes_v03.hipnc (218.8 KB)
bebe
it's always been this way and I was wondering s well, but since VDBs were developed independently, maybe this was inherited behavior
A quick note (on VDBs): if you're transforming a velocity-like volume, make sure the “Vector Type” is “Displacement/Velocity/Acceleration”. (You can set it on a VDB SOP or a Primitive SOP). That way your velocity values will be transformed (e.g. rotated) properly. I don't think it works with regular volumes, though
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
