How delete particles from whitewater?
   Views 4748   Replies 5   Subscribers 0
I set up a little waterfall simulation. As you can see a bunch of particles fall through the rocks, and I want to delete them. Can you help me how?
Thank you
And I tried with a sink object but didnt worked.
different ways, you can add an attribute wrangle
if(@P.y < 0) {
    removepoint(0, @ptnum);
you can also use a delete Sop and use the delete by expression and add
@P.y < 0
make sure to change it from primitive to points
Thank you For your help. But I have a little problem. Im not sure I understand well but this will delete every particles below the y 0, right?
I think I cant explain so I show it to you.
https://vimeo.com/219340879 [vimeo.com]
I would like to delete the perticles under the rock. On the other sides it call fall below 0 because the waterfall is on my table so if I delete all the point it wont reach the ground.
then you can use the delete node with a bounding box just where you want it. You might be able to use as well the POP Kill.
Edited by sepu - June 10, 2017 23:17:49
Thank you .
