houdini deep rendring
   4111   1   0
hi someone know how to render deep pass render for volume like smoke,can someone tell full process or make hip file with volume very argent for project. in deep render menu i just on camera deep pass and give the image path with dcm file with exr extension,and second roll out front and back z depth. is it enough for deep pass?
and also you should add Deep resolver parameter to the Camera node and set it to Deep Camera Map.
Rabiee.Sadjad@Gmail.Com
