i've already searched in the forum, looked several tutorials but still i can't find an answer, so i've decided to open a topic in here.
As you can see from the attached pictures, the two objects are correctly showed in Houdini, but as soon as i create an asset with them, and i export this into UE4, the box is fine but the tower has some kind of a “reversed” view.
Also, this is altering the collision as well, because the character gets stuck inside.
(I'm facing the same problem even with a simple .fbx format.)
I think that the Polyextrude node is creating some trouble here, since the tower is all made out with it and the box is not.
Is there any workaround for this issue? Are you already aware of this problem?
I'm using Houdini 16.0.621 & UE4.16.1 (with the Houdini Engine correctly installed)
Polyextrude creating problems with the Asset
4992 6 0- LukeWolf
- 4 posts
- LukeWolf
- 4 posts
- trojanfoe
- 67 posts
- LukeWolf
- 4 posts
Thanks trojanfoe, with that option on i can now see in the same way UE4 sees it. I see here that the problem is with the “Back-face culling”, am i right?
Is this Culling defined by the Primitive's normals?
Now, even if i use a simple Wrangle that says: “@N *= -1;” (running over the primitives) i still see the lines going in the previous direction, but their values inside the spreadsheet is now reversed, how can it be? D:
- trojanfoe
- 67 posts
OK, first off I'm no expert but from my experience the front face is defined from the winding-order of the vertices. They need to be anti-clockwise (or maybe that's “counter-clockwise” where you live). I know this for sure as I recently created a “profile” to Sweep along a curve in order to make a wall. This is the code that works within a Detail-level Attribute Wrangler:
If I add the vertices as 0-1-2-3-0 then the normals are inverted and I needed to use a Reverse SOP to correct them (the usual way of fixing flipped normals).
float height = ch("../height"); float top_width = ch("../top_width"); float bottom_width = ch("../bottom_width"); int pt0 = addpoint(0, set(bottom_width * -0.5, 0.0, 0.0)); int pt1 = addpoint(0, set(top_width * -0.5, height, 0.0)); int pt2 = addpoint(0, set(top_width * 0.5, height, 0.0)); int pt3 = addpoint(0, set(bottom_width * 0.5, 0.0, 0.0)); int prim = addprim(0, "poly"); addvertex(0, prim, pt0); addvertex(0, prim, pt3); addvertex(0, prim, pt2); addvertex(0, prim, pt1); addvertex(0, prim, pt0);
Edited by trojanfoe - June 25, 2017 08:12:14
- LukeWolf
- 4 posts
- dpernuit
- 553 posts
