I did the “ball drop on a table” DOP tutorial, works fine.
I'm trying to get the ball to roll down a tube, then hit the vase.
I added the tube as a (inactive) rbd object, but the ball either stops right at the mouth of the tube or else falls right through it like it wasn't there. I'm reading the docs and experimenting with the settings, but no luck yet.
When I added a default “geo” (box) and flattened it out, and used it as a “ramp”, it the ball did roll down the surface. It seems rolling *inside* an object is a bit trickier
Mike
