Error license Mantra - Houdini Indie license
   2885   1   0
Hi there!
I've an issue with the rendering. When I want to render something with Mantra, a message tells me that "No licenses could be found to run this application. Please check for a valid license server host.
I've a Houdini Indie license and I thought that I can render with the indie license.
if anyone can help me on this
thank you
Just contact support@sidefx.com. Yes, you should be able to render with an Indie license. There is a size limit to final images that you can render with Indie, however. Are you exceeding the size limit?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
