Arnold Per light AOV
   Views 12501   Replies 3   Subscribers 2
I need to render out Per light AOV in Arnold. Please help me out with instructions. I googled about it and found some instructions in solid angle, but I'm not getting that light expressions box in my Arnold render settings.
I know this is an old post, but since I just figured out how to do it I might as well answer for the next generation:
It's actually quite easy.
When you choose a AOV in the dropdown, for example “RGBA”, you just change this to “RGBA_*”, which means it creates a RGBA AOV for every light group. Same for example for diffuse: Instead of just “diffuse” you change it io “diffuse_*”.
It is important though to create a ligth group for your lights. A light group is kind of an id for one or many lights. you can set the light group of a light in the Contribution Tab> AOV Light Group.
Unfortunately the documentation from solidangle does not describe the method very well…
Cheers
Edited by ChrisBohm - June 25, 2018 13:07:07
ChrisBohm
Cheers
Works like a charm!! Thanks Chris!!!
ChrisBohm
When you choose a AOV in the dropdown, for example "RGBA", you just change this to "RGBA_*", which means it creates a RGBA AOV for every light group. Same for example for diffuse: Instead of just "diffuse" you change it io "diffuse_*".
Unfortunately the documentation from solidangle does not describe the method very well...
Cheers
Thanks a lot for sharing!
