centroid instead of $CEX ?
   15688   2   3
So apparently you cannot use $CEX, $CEY, CEZ anymore?
I get a
syntax error, invalid syntax
But how would you use centroid() on the Pivot parameters of a Transform SOP inside a For Each block?
If I try
centroid(opinputpath("."),0)
I also get an error,
Unable to Evaluate expression. Name ‘centroid’ is not defined
http://www.sidefx.com/docs/houdini/expressions/centroid [www.sidefx.com]
I can use $CEX, $CEY, $CEZ with no problems.
You have some typos in your centroid expression, this works for me:
centroid( opinputpath( ".", 0 ), D_X )
centroid( opinputpath( ".", 0 ), D_Y )
centroid( opinputpath( ".", 0 ), D_Z )
Edited by A-OC - Aug. 14, 2017 01:20:16
I had similar issue. For those who are looking for solution check this link:
https://www.sidefx.com/forum/topic/43043/?page=1#post-293793 [www.sidefx.com]
Edited by prrrszalony - Sept. 12, 2019 15:28:20
