rotate point normals around tangents in vex
   9087   4   2
I know this has been asked before, but I simple can't get this to work correctly.
I got a curve with a lot of points. I put N and Tangentu on the points with a polyframe and in a Pointwrangle I have the following:
___
float twist = chf('twist');
vector tnorm = normalize(@tangentu);
matrix3 m = ident();
rotate(m, twist, tnorm);
@N *= m;
___
- twist is a float slider.
The Normals rotate, but on some weird axis. I obviously need them to rotate around Tangentu
Hip file attached
twirlsetup3.hip (71.8 KB)
you can use primuv to evaluate “tangentu” from first input.
twirlsetup3X.hipnc (66.8 KB)
Here's another way, using edge_dir attribute from a point SOP
twirlsetup4.hip (77.5 KB)
@moogtastic, thanks!
It wasn't even the assignment of tangents that was off. It was the syntax in my vex.
This worked:
___________
matrix m = ident();
rotate(m, twist, v@tangentu);
@N *= m;
I know this is a very old post, however I was wondering, with current setup, how would you drive rotation by an attribute such as Cd, P...
