UVTexture - Cylindrical perfect mapping
   Views 7256   Replies 18   Subscribers 5
Need some help.
I want to map a texture using UVTexture - Cylindrical type.
All goes fine when the box is 1x1x1 meters.
As long the box changes the proportions in x , y , or z the texture is distorsed.
¿¿Is there a perfect formula to fix it and get near-perfect quads in the mapping???
For boxes and rectangular surfaces you could just use cubic mapping:
http://forums.odforce.net/topic/18451-uv-cubic-map-procedurally/ [forums.odforce.net]
Hi again Konstantin,
its not for a perfect box. Its for a chimeney.. it has bevel surfaces on borders(polybevel) and one curvature in center (polyextrude + curvature).
I can control at tall in Y. The problem comes when changing chimeney size X and Z.
Edited by bhb - Sept. 13, 2017 21:04:36
I´d still say use cubic mapping.
Edited by Konstantin Magnus - Sept. 14, 2017 02:17:54
pillar.hipnc (145.2 KB)
That image you posted here looks fine.
Yesterday, I tried the vertex wrangle you posted, and didnt worked for me.
The -X, X primitives UVs are rotated 90º down.
Attribute Wrangle(Vertices):
vector bbox = relbbox(0, @P);
vector side = sign(@N);
vector nml = abs(@N);
vector size = getbbox_size(0);
vector ratio = size / max(size);
vector scale = bbox * ratio;
//if (nml.x == max(nml)) { @uv = set(-scale.z * side.x, scale.z, 0); }
if (nml.x == max(nml)) { @uv = set(scale.y * side.x, scale.z, 0); }
else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, scale.z, 0); @uv.y += 1; }
else { @uv = set(scale.x * side.z, scale.y, 0); @uv.y += 2; }
@uv *= 0.3333;
@uv.x += 0.5;
You probably have to switch two vector components in the code or so. I will look into it over the weekend.
if (nml.x == max(nml)) { @uv = set(-scale.z, scale.y * side.x, 0); }
else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, -scale.z, 0); @uv.y += 1; }
@uv *= 0.3333;
@uv.x += 0.5;
Hi again Konstantin Magnus,
I tried your fix and the faces are oriented right, but the problem is in the edges, .. the textures are not aligned well.
That method you described is great for fast uv-mapping and paint after outside with Allegorithmic Painter or Mari.
What do you mean? The script is just doing cubic UV mapping. All it does is dividing UV islands by the primitives main orientation. And its mapping straight from the sides.
Maybe append a UVlayout node, but it´s a bit hard to tell what you are after.
Edited by Konstantin Magnus - Oct. 21, 2017 08:45:08
Texture pattern doesnt warp around right.
What about simply adding some cuts?
Or, maybe “easier”, use a procedural stone shader?
Edited by matthias_k - Oct. 22, 2017 11:03:51
uv-test.hip (138.5 KB)
Same problem. The pattern dont coincide where the seams are cutted.
Hi, that's right, but you can manually remove the cuts.
I made them to avoid distortions.
Maybe then UV edit/move the points.
If I'm right, then you'll need for perfect fit,
a volume based shader or real geometry.
Edited by matthias_k - Oct. 22, 2017 11:42:55
If you want all projections to line up, you have got to simplify the code a little:
else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, -scale.z, 0); }
else                        { @uv = set(scale.x * side.z, scale.y, 0);  }
@uv = abs(@uv);
Better but not perfect. Line-seams in the edges.
A texture can not work on a diagonal in/outset in my opinion.
Only if you repaint it, to match the border.
What about using real geometry, then project to lowres geometry?
wall_test_b.hip (779.5 KB)
That is Mathias, the code supported by Konstantin is very good if we want to paint after outside in Mari or Substance Painter. There are little seams that are appreciated when the camera is near them.
I tried another way using node UVProject (Cylindrical). But same as UVTexture, when the proportions of the chimney changes the texture 1:1 ratio distorses.
For the “real geomtry projected” I will try soon the file you uploaded. Thanks.
Edited by bhb - Oct. 22, 2017 15:03:34
If you need it only on the sides, with small convex shape…
then maybe define first UVs, then deform.
This should give a perfect match, if the texture is seamless.
Ups, vertical line should have same point count like the lattice deformer (4)
Edited by matthias_k - Oct. 22, 2017 15:38:09
other_way.hip (307.1 KB)
Better…
to change the width, depth, modify the “curve1”, the multiplier for the UVs
is:
vertical the height of the “line1”
horizontal the point count of “curve1”
with this 2 values in mind you can easilly add a UV transform and set right multiplier.
Edited by matthias_k - Oct. 22, 2017 15:50:09
other_way.hip (308.4 KB)
