point wrangle - data between iterations?
   2354   3   0
hello.
I would like to share and change data between point wrangle iterations.
is it possible?
ex: array which is filled in every iteration
thanks
you'll need to have your wrangle either in For loop (feedback) or Solver SOP
FX Supervisor
Method Studios, NY
Thank you Tomas.
Unfortunately I need to have the data exactly inside the wrangler. As example:
Array which is collecting @P.y value from every point and checking is the same value is already in array.
then you can use Detail Wrangle and for loop inside, looping over all points
float @uniquePyArray[];
int npt = npoints(0);
for(int pt=0;pt<npt;pt++) {
    vector P = point(0, "P", pt);
    if (find(@uniquePyArray, P.y) < 0) {
        append(@uniquePyArray, P.y);
Edited by tamte - Oct. 28, 2017 13:54:36
FX Supervisor
Method Studios, NY
