BUG: Can't interupt Divide SOP
3958
5
3
pbowmar
Jan. 27, 2006 6:43 a.m.
Hello, Make a box 50x50x50, throw on a Divide SOP with default settings, turn on Bricker. Now, try to interupt it. At least with Threaded UI on, no dice. Get out the kill -SEGV if you want to work again anytime soon ) Cheers, Peter B
Cheers, Peter Bowmar ____________ Houdini 20.5.262 Win 10 Py 3.11
Simon
Jan. 27, 2006 8:34 a.m.
I think the defaults for bricker should be very large, that way when you first turn it on you aren't in danger of creating a billion polygons…..
pbowmar
Jan. 27, 2006 9:32 a.m.
Yep, that's my thinking too. Maybe have it look at the incoming geo's bbox and set the divisions to something appropriate, or something like that? Cheers, Peter B
Simon
Jan. 27, 2006 9:42 a.m.
Maybe it should have some options like the metaconvert sop, Divs per bounding box and Step size.
pbowmar
Jan. 27, 2006 9:44 a.m.
That'd be cool, definately. I use bricker a lot, often just to clean up nasty poly problems and so forth. Cheers, Peter B
peliosis
Jan. 27, 2006 7:40 p.m.
Ha! That bricker thing is bored with hearing my curses over and over.
I somewhat like that: “Aaaarghhh!!! not again!!!!” surge
