This question has probably been answered several times, but I have not yet found a solution. Is it possible to display and change the dimensions of an object or its bbox? Just like you can do in cinema 4D or Maya.
When I import an object, the size is always displayed as 1. However, the lethal word size is often different.
I'm new in Houdini, so sorry if the question sounds stupid.
Word Size
1411 3 1- filmfritze
- 3 posts
- Konstantin Magnus
- 686 posts
You can access an objects dimensions with bbox: eg. bbox(0, D_XSIZE).
Position would be centroid: centroid(0, D_X), centroid(0, D_Y) or centroid(0, D_Z) respectively.
Here are more expression functions: http://www.sidefx.com/docs/houdini/expressions/index.html [www.sidefx.com]
- filmfritze
- 3 posts
- Konstantin Magnus
- 686 posts
You would merge all objects on geo level.
On object level you will only find containers and you would not really know what nodes within are supposed to be measured.
