Hi SESI.
When working with the Edit SOP and using the Soft Radius to smoothly edit points it would be great to have some visual feedback of what is the scope area of the radius, with a degraded colro for instance, from more effect to less.
And it is possible to extend the soft editing to edges and primitives?
RFE:Edit SOP softh radius visual feedback
4597 6 3- lisux
- 581 posts
- Siavash Tehrani
- 729 posts
This is a good RFE.
The visual feedback, is something max has had from the beginning (infra-red type visualization). Houdini's smooth falloff is much nicer though because it's “active”. Last time I checked in max (which I admit was a while ago) you couldn't change the radius of the falloff interactively.
- pbowmar
- 7046 posts
- Simon
- 2199 posts
- lisux
- 581 posts
- Mikael_Amion
- 129 posts
- jabbermacy
- 12 posts
DaJuice
This is a good RFE.
Sure you can - check out RO tools - search CGtalk, you'll find (and LOVE) it! Trust me, bro - REALLY check out the options in these and CHECK THE VIDS - there's a ton of good stuff!!
