Apprentice licensing problems too
   5736   7   1
I tried installing the latest production build (8.0.474) but had no luck getting the key installed. Everytime I launched Houdini from the Start menu, it would connect to license server & ask if I like to automatically install a non-commercial license. I click on the link , accept the EUA - then in a bit it comes back saying the licenses were successfully installed. I choose to run Houdini and whoops … it starts asking about the license again … and around and around we go.
So, noticing someone else on the forums was having problems, I decided to try the latest build (8.0.506). So, I did the following:
- uninstalled all versions of Houdini
- downloaded & installed 8.0.506
- rebooted
- checked to make sure both services up & running
- made sure there was a Cwindows/keys folder
- connected to Internet
- ran Houdini from Start menu and boom … same problem
Diagnostic reports (edited version) …
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Wed Feb 08 22:17:01 2006
Local host name: DAISY
Local server code: 096aeb5b
Local ip address: 127.0.0.1
Number of servers: 1
License server name: daisy (daisy)
License server server code: 096aeb5b
Server ip address: 127.0.0.1
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: No
License server version: 8.0.506
May modify server from this machine: Yes
Redundant server keys: 1
Name Code Redundant Connected Transmission OK
daisy 4ca99979 no - -
License Administrator version: 8.0.506
Http proxy host: (none)
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
c139b5d2 Generic Houdini-Master-NonCommercial 8.0 0/0 10-mar-2006
+.+.+.+ daisy (license known to: daisy)
cff60f9a Generic Render-NonCommercial 8.0 0/0 10-mar-2006
sesictrl -i output:
—– SERVER daisy ——–
*** WARNING *** - No valid server lines found
Lic c139b5d2: 0 “Houdini-Master-NonCommercial 8.0” Generic 10-mar-2006 +.+.+.+ daisy
Lic cff60f9a: 0 “Render-NonCommercial 8.0” Generic 10-mar-2006 +.+.+.+ daisy
Serv daisy 4ca99979
redundant: no
connected: no
transmission successful: no
hserver -l output:
Hostname: DAISY
Uptime: 0:34:36
License Server: daisy
Server Version: sesinetd8.0.506
Version: Houdini8.0.506
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
547 of 1023 Mb available
CPU Usage: 0% load
0 active tasks (2 slots)
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 18:24:24 02/08/06
LICENSE Generic Render-NonCommercial 8.0 1 10-mar-2006 +.+.+.+ daisy \
cff60f9a 8Z5FZ3J@MUrs7rcfCrMYh9Jq9YEickPcNUwFLxY7r8IaIrOVkwsAA31
# Key installed 18:24:27 02/08/06
LICENSE Generic Houdini-Master-NonCommercial 8.0 1 10-mar-2006 +.+.+.+ \
daisy c139b5d2 \
dn0a0F0h5PsO8ug1ZJ+T8pOl8K1SF+@nXjho7p4vRyf7hrGx1kzP3Q3
Do I need to install manually? If so, what's the webpage to get the key? Any help would be appreciated.
EDIT:: should have mentioned that I'm running WinXP 32bit
Rob
Digital Supervisor | Stargate Studios Toronto
had the same problem since arriving
to the U.S. its most likeley a dynamic IP thing.
here they charge extra for static IP!
- another US backwardness story for the ppl back home.
Try the latest daily build, that's working
here… for now.
After some digging, I was able to get the Apprentice version up & running. I had to go & get the keys manually then edit the file Cwindows/keys/license.
I would still like to know what went wrong last time. Ideas?
Rob
It just doesn't work in windows - you need to manually install - check my thread (with no real answer)… but it works, so f-it
The problem for rdms it looks like was this:
Two license keys were installed but the server license was never installed. Was the license file manually created?
edward
Just to be clear …
The license file (Cwindows/keys/license) has been there ever since I first installed the Apprentice Edition back in early ‘04. I’ve never had any problems before updating the NC license.
However, this time around, I had to manually do this. I renamed the original license file (license -> license.old) then copy/paste lines from the webpage into a new license file.
Edward, the server license is the first entry in the license file, right? This is what I see …
# M5V 3E7
# Key installed 23:12:34 05/01/04
SERVER daisy <bunch of numbers here>
It's very strange that the diagnostics didn't see this. Anyways, it's working and that's all I care
Rob
Rob
Are the server codes between the working and non-working license files the same?
edward
Nope … completely different. Did SESI change something to generate new server codes? Nothing changed on my box. :?
Rob
