Redshift Install breaking Mantra on Linux
   4693   2   2
I'm currently running Houdini 16.5.268 in CentOS 7. I have Redshift 2.5.49 installed and Arnold as well. Currently, if I drop down a mantra node in even the simplest of scenes, I get a lot of strange Redshift messages in the terminal when I attempt to render. The renderview says Generating Scene; the scheduler says the mantra process is running. I get the following output in the console.
Redshift for Houdini plugin version 2.5.49
Plugin compile time HDK version: 16.5.268
Houdini host version: 16.5.268
Plugin dso/dll and config path: /usr/redshift/redshift4houdini/16.5.268/dso
Core data path: /usr/redshift
Local data path: /home/rramirez/redshift
Procedurals path: /usr/redshift/procedurals
Preferences file path: /home/rramirez/redshift/preferences.xml
License path: /home/rramirez/redshift
00:00:00 309MB | log started Thu Dec 21 00:31:51 2017
00:00:00 309MB | Arnold 5.0.2.1 linux clang-5.0.0 oiio-1.7.17 osl-1.9.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.2.2 2017/11/17 14:06:00
00:00:00 309MB | running on linuxHome01, pid=24960
00:00:00 309MB | 2 x Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz (16 cores, 32 logical) with 64139MB
00:00:00 309MB | CentOS Linux 7 (Core), Linux kernel 3.10.0-514.26.2.el7.x86_64
00:00:00 309MB | soft limit for open files raised from 4094 to 4094
00:00:00 309MB |
00:00:00 309MB | Registering shaders …
00:00:00 309MB | loading plugins from /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/plugins …
00:00:00 310MB | htoa_mandelbulb_proc.so: mandelbulb uses Arnold 5.0.2.1
00:00:00 310MB | loaded 1 plugins from 1 lib(s) in 0:00.00
00:00:00 310MB | Loading metadata file: /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/metadata/cameras.mtd
00:00:00 310MB | Loading metadata file: /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/metadata/lights.mtd
00:00:00 310MB | Loading metadata file: /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/metadata/options.mtd
00:00:00 310MB | Loading metadata file: /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/metadata/shaders.mtd
00:00:00 310MB | Loading metadata file: /home/rramirez/htoa/htoa-2.2.0_r9912855_houdini-16.5.268/htoa-2.2.0_r9912855_houdini-16.5.268/arnold/metadata/shapes.mtd
00:00:00 312MB | shader registration done.
00:00:00 312MB |
00:00:00 312MB | releasing resources
00:00:00 273MB | Arnold shutdown
No licenses could be found to run this application.
Please check for a valid license server host
Closing the RS instance. End of the plugin log system.
Is this some kind of weird configuration error? Anyone seen this? I can't render in Mantra at all.
Actually, I think it's not Redshift breaking anything. This has only happened since I installed Redshift but I was reading the logs incorrectly maybe. Arnold renders fine; Redshift renders fine; Mantra does not render at all, even when I remove Redshift and Arnold from my environment.
Actually I'm having a similar problem with the same log info but in windows, suddenly mantra stops rendering and display a redshift description error.
Anyone have any solution?
Julian Rodriguez
